If new means reproductions, the problem is common. If new means new to the tractor, but from salvage, I would indicate a different issue might be on tap. If the trans has not been taken apart, and is not free to move axially (thrust washers are in place) I would braze weld up the hole and re-drill it as needed. (Jim Braze weld is using the brass as filler to relocate the hole.) Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
