Posted by jeep258goat on October 06, 2011 at 10:45:55 from (12.180.248.116):
OK, 50ish farmall cub. I reworked the valves, put back together everything and even put the plug wires on right this time. I got good compression now and i have spark going through the spark testor tool that you put on the plug and then into the plug wire. I believe i am at TDC, set the short side of the rotor button at #1ish position and then try to fire. I have put new point and condensor in and calibrated at the manual required spec. have good fresh gas flow at the carb. it is chugging with a puff of white smoke out of the muffler but will not catch and start. i feel like i still don't have timing or even the 6 volt system is not spinning engine fast enough. i am using original switch but if there was a problem here i would think i would not have spark at the plug? Need some more help on this one. I did remove the distributor from the tractor,,,could i have put it in wrong?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
