Posted by ADLM on October 11, 2011 at 13:59:58 from (72.156.145.199):
I am finding that my Farmall A does not like to go into gear after I first hit the clutch when the transmission is in neutral. It will not go into any gear unless I force it in, making the gears grind a lot in the process. Then, I can drive it, use the pto, and change gears just fine without any grinding at all. But if I ever let out the clutch with the tractor in neutral, when I try to go back into any gear the same grinding process as before is repeated. It does not matter how long I wait after pressing the clutch, if I'm in neutral the gears will grind. Does this mean time to replace a clutch, or is something else causing this problem?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
