The way I get stubborn steel pipe out of cast is to torch-cut it. First cut off the pipe about 1/2" above cast. Aim the torch down the pipe edge and zap it with oxygen. You will have a nice complete kerf down in the pipe but the cast thread will be unaffected. The 1/2" stub is for starting the oxidizing cut. This all happens very quickly. Don't linger or the cast threads will be affected. Might want to practice on some old cast iron plumbing fittings first. If you make three cuts 120 degrees apart, the pieces will fall out but only one cut is necessary.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
