I found two spots on the head that are questionable. The first is the space between the very front of the head & cyl. #1. I can fit the .002" but not the .0025" in there. The second spot is between cyl's 2 & 3. I can fit the .002" gauge in there. The spot where the blow-out was, I can fit no larger than the .0015" gauge. There does not seem to be a taper there. However, the spot between 2 & 3 has a slight taper. I could move the .001" gauge about 2" from side to side, between the coolant holes. I went over the head & top of the block, again, to get a cleaner surface. I would assume it is good to go, for now?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
