Posted by Janicholson on October 23, 2011 at 06:12:35 from (96.24.99.126):
In Reply to: 27v hook up help posted by brian1855 on October 22, 2011 at 20:51:21:
Simi mounted draw bar mowers have no problem using the rockers to provide lift. A 3/8" cable is used to provide pulling force on the lever. pulleys are used to direct the force so that it is directed from drawbar level to the lever. The lever action might be dangerous to the operator such that cutting or modifying the lever, or replacing it with shorter flat stock to preserve the original might be wise. The pulley/s should have a fair lead so that the cable is constrained to the groove. More than one pulley might be needed. loops for the ends of the cable should have protection, see link. Good luck, and do not use a solid link, it would lift and drop with trailing tire motion. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
