Re: How do I put new gears in a teledepth hydraulic valve?
Posted by moondoggie on October 25, 2011 at 18:32:56 from (66.187.36.240):
In Reply to: How do I put new gears in a teledepth hydraulic valve? posted by DMartin2 on October 24, 2011 at 20:41:29:
The I&T manual has the instructions for assembly of the valve. The gears and the yoke are set in a neutral position and the input and follow-up levers are set to specific angles from vertical. I've done this on a 340 but don't know if the angles are the same for a 460. On the 340 it also depends on whether the cable or rod system is used for the teledepth valve. On the 340, the axis of the yoke and gears is parallel to the cover surface; the input lever is set to 7 1/2 deg. to the rear from vertical; the follow-up lever is set to 6 deg. to the front, from vertical. Hope this helps.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
