Posted by Mike Dau on October 28, 2011 at 16:17:04 from (173.25.38.117):
I'm in the process of tearing down the engine on my '37 F-20, and at this point it's just the block and crank that's left. (and a couple of valve tappets that there doesn't seem to be any way to get out of the block, but that's another matter.) I've got a service manual that specifies tolerances for the connecting rod bearings, but it doesn't give any info for allowed play in the main bearings. There's no longitudinal (front-to-rear) play in the crankshaft, and the rear bearing has no lateral play in it, but the front bearing does have some. My question is: How much is too much? I want to rebuild the engine properly, but at the same time, I don't want to go through a lot of extra work and expense replacing a front main bearing that's ok as-is.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
