Posted by Tom Fleming on November 02, 2011 at 18:02:19 from (206.193.250.146):
In Reply to: shutting of an A posted by charlie M on November 02, 2011 at 08:45:30:
Well, the screwdriver from the terminal to the body of the mag should shut it off.
Also, the ON/OFF grounding switch only works if it has good ground at the mounting point. if there is rust or paint between the body of the ON/OFF switch, and the mounting hole, it will NOT ground out the mag. Also, if the mounting bracket is not well grounded to the steering post. same result.
So, bottom line, new switch or not, if there is not good continuity between the switch body, and the body of the mag, it won't shut it off.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
