The bar thickness comes from the width of the slot in the touch control arm.
Length can be done many ways...
If you've got a picture, you can print it out, measure the bar, then measure something else on the tractor in the picture (such as the oil filter canister width). Measure your real-life oil filter canister width, and use that to scale up your measurement of the bar.
You can eyeball it. I would start out with a 12" bar. It should be more than enough. If it's too much, simply drill another hole for the chain closer to the touch control arm.
All the arm has to do is go low enough to give you enough chain slack to unhook it, and lift high enough to get the mower off the ground.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
