cheap tubes
Posted by soundguy on November 25, 2011 at 14:14:29 from (173.105.192.17):
front went flat on my C, broke it down, nobody but TSC had a 4/5-15/16 tube.. so got that.
I typically don't put a ton of air pressure in a tube while it's out of the casing. just inflate to check for leaks, then deflate and instal.
got this one in, sot the air to it and constant leak around stem :(
broke it down, a seam had split at a corner.. or at least they look like seems..
anywho.. I've got a farm patch curing onit now and will give it a try sunday morning.. my next free time to work on it.
GRRR... cheap tubes...
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
