Re: water in oil 52 farmall h
Posted by JRSutton on November 29, 2011 at 16:30:33 from (75.130.109.233):
In Reply to: water in oil 52 farmall h posted by Paul Scott on November 29, 2011 at 16:18:44:
Head gasket is always a first guess for water in the oil.
Pull the plugs and crank the engine - see if there's any obvious water spraying out.
Check the compression while you're there.
no water and decent compression doesn't prove the gasket's good, but finding water or bad comperssion will make you feel better about going through the trouble of pulling the head.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
