What have you tried to get the retrieve the key. A small magnet might work. A rag stuffed in just the right place and turning engine correct way to work key back up. You would have to have the pump adaptor drive housing installed to do that to hold gear in place. I can't recall if the bottom of the front cover is open or closed by crank shaft gear to make key accesable with pan removed. May have to pull front cover.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
