Posted by D Slater on November 30, 2011 at 17:02:48 from (184.15.30.71):
In Reply to: Re: Tranny problems posted by mark20 on November 30, 2011 at 16:08:27:
You will need to install the M axles and axle housings to the w6 transmission housing, also brake and clutch pedals and associated parts. Reason you can't install the just the W6 4&5 sliding gear and main shaft in a M is because of different gear ratios. Gears they mesh with have to be changed also. If you switch a M or W6 ring and pinion into the other tractor transmission use the rear bearing retainer for the main shaft that goes with the R&P set. Bearing retainers are different although at first glance they look the same.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
