Re: Engine seize question
Posted by Scotty HOMEy on December 03, 2011 at 20:15:39 from (70.105.240.226):
In Reply to: Engine seize question posted by BigTone on December 03, 2011 at 14:20:15:
If the belt and all pulleys attached to it will turn with effort on the fan blades, it is not siezed.
If that doesn't happen, check out the belt tension and adjust if necessary for another check before assuming the worst.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
