From your picture number one of the fuel level, I would take a swag at it being very close to correct from my experience with other carburetors. If the float is adjusted so it is parallel to bowl mounting surface when inverted I would just leave it there. It sounds like you have a main jet that is too small. There are so many different carburetors that I can not tell you exactly how yours is. If you have an old carb like it I would take the main jet out of that and try it. I am assuming main jet is screwed in on that one or is part of the main nozzle. I have a set of wire gauge drills that come into play after I have ruled out all other possible problems. Newest fuels do not always perform same as the older gasoline carb was calibrated for. Not much help I guess.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
