Posted by John T on December 11, 2011 at 10:19:31 from (173.243.181.15):
In Reply to: Super C coil issues. posted by Agricon on December 11, 2011 at 09:13:36:
If you were to put a test lamp on the coils input (NOT to distributor) terminal (other test lamp lead to frame ground) and turn on the ignition, THE LIGHT SHOULD LIGHT AS VOLTAGE SHOULD BE PRESENT
HOWEVER if the tractor is just setting there not running with ignition ON and you put the lamp over on the output to distributor terminal ID EXPECT IT TO BE OFF SINCE THE POINTS ARE LIKELY CLOSED THEN.....(if alls wired up correctly and the points are working good and closed)
If you turn her on and crank her over a test lamp on the coils output or distibutor input (from coil) terminal should flash ON (points open) and OFF (points closed)
Heres my Ignition troubleshooting procedure, give it a try
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
