Re: axle removal
Posted by D Slater on December 15, 2011 at 06:40:28 from (184.15.30.71):
In Reply to: axle removal posted by Dudley Brand on December 15, 2011 at 05:37:56:
Jack bolt and pipe between axles with inside retaining bolt removed from the axle to be removed or a portapower press.
No disrespect intended but I better ask if you removed the bolt and large washer from the inside end of the axle.
Run into extreme ones a couple of times that I was afraid something in the housings was going to give before the axle moved in the splines.
Once had to remove axle and housing on the other side and rig up a big jack to push out.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
