Hi, that block by the clutch housing is a flow divider and pressure relief valve for the PS. The flow divider is supposed to split off 2-3 GPM of hydraulic flow from the high pressure line from the pump and divert it to the PS. You can see a parts break down on caseih.com search for parts B414 steering. I suspect either the flow divider is not diverting 2-3 GPM to PS or the pressure relief valve is not allowing the correct pressure to PS.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
