Posted by Rod in MN on January 03, 2012 at 05:07:46 from (66.242.67.252):
In Reply to: M Governor Adjustment posted by Rod in MN on January 01, 2012 at 12:17:31:
Hi took the Gov off the tractorto check out all parts inside thet all were good. The Gov housing did not have the bumps showen in the book. Made a longer bolt to adj high speed stop as per IT book to get no pressure on spring. Checked pin in upper rod pin was losse. start a run tractor adj carb but no high speed. Installed short bolt to adj stop had lot of spring presser on spring.Ran tractor could get high speed. But why so much spring presseur on spring it works ok ????
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
