That's actually a BN. It used the same axle tube as the A. The B used a wider one. An easy way to ID a B vs BN is the right side seat bracket. On a B there is space between it and the fender.
The B never came with hydraulics, as it was replaced by the C after a few years. Supposedly some late B's came with a provision for the hydraulic pump cast into the block.
The seat is the same, the battery came under the seat instead of hanging by the starter like in the top picture.
Other than the A had hydraulics available, and the extra /wider axle tube(s), and front axle/bolster, they are identical.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
