Posted by Zachary Hoyt on January 09, 2012 at 14:59:03 from (184.12.66.170):
In Reply to: h timing cover removal posted by Drewbee90 on January 09, 2012 at 14:45:04:
I am not sure about the front bolster, but I think there should be room. Crank pulley definitely needs to come off, the nut is easy to remove with a large crescent wrench if you don't have the correct wrench or socket. There is a stealth bolt on the governor that hides and will prevent the cover from coming off if it is not removed. It tends to get covered with oil/grease and dirt. Zach
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
