The four most common issues: Head gasket. Look it over to see if it was black/deformed at the oil passage to the head. "O"rings at the bottom of the sleeves (wet sleeves)Look up under its bottom end with the pan off. green around the sleeve bases is a giveaway. Cracked head or block. Look for signs of cracking have the head cracke checked. Rusted out Welch plugs (soft plugs, core plugs (not freeze plugs but called that)) These can let water into the pan radically, or slowly at first. look under the front cover for internal plugs. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
