Posted by Zachary Hoyt on January 15, 2012 at 10:11:32 from (184.12.66.170):
In Reply to: transmission seal posted by dcpky on January 15, 2012 at 09:52:36:
I put a bolt through the cotter pin hole on my belly pump drive shaft and put a nut on it. Then I put the shaft back in place and put a 24" crescent wrench on it and it came off fine. That being said I did part out an H in November/December that I could not budge the countershaft nut and I ended up cutting off the flange and cutting a flat on the seal surface with a cut off wheel. I think the heat was what finally made that come off, but I have never had one that was that stuck before. It was damaged anyway so I didn't feel much compunction about cutting it up to get it off. Zach
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
