Posted by cheif on January 16, 2012 at 06:36:34 from (184.61.129.34):
I need to replace the front transmission seal on my international A. My service manual is not very clear to me on how to access the seal . Must I split the tractor at the clutch and move the engine forward then split the housing at the transmission? Can I then remove the transmission drive flange to access the seal or do I have to disect the transmission further? when I pull the engine forward will the clutch shaft just slide out of the throwout bearing and release sleeve? This is a 46 model and I have replaced the final drive and axle seals, they were still the original leather type and very leaky. I suspect the transmission seal is the same type. Thanks for any advice!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
