Re: 2514B BACKHOE
Posted by gurneejoe on January 18, 2012 at 05:09:08 from (205.188.116.73):
In Reply to: 2514B BACKHOE posted by BOB ONEILL on January 17, 2012 at 18:42:23:
If this is the same as a 2500B I would look for bleeders at the top of each axle housing or just above the housing on the main case. If you open them when the engine is running they should slowly flow until the air is out of the brake pistons. There are brake discs and piston between the axle and the case. In order to replace the piston o-ring the axle housing comes off. They use oil from main reservoir so make sure it isn't low. It would be obvious if the hydraulics are noisy or jerky. You could open the bleeder and push the pedal with a helper but engine should be running to keep the master cylinder suppied with oil.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
