Posted by BruceS. on January 21, 2012 at 06:34:29 from (76.15.41.164):
In Reply to: farmall md fuel systems posted by jim warehime on January 20, 2012 at 18:44:07:
When I got my MD, someone had installed a fuel bowl on the diesel tank. I don't know if they did that to correct the problem you are describing or not. My tractor runs just fine with that setup. YOu might consider it if all else fails. The one drawback is that your fuel line will probably not line up with the fuel bowl fitting. Mine was cut off a few inches and replace with a rubber hose. Certainly not factory, but it's never been a problem. As for the carb drain, something as simple as teflon tape might fix it, or try anerobic sealant (available at NAPA). That stuff really does work wonders on hard to stop leaks.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
