Posted by Tom Fleming on February 08, 2012 at 15:53:07 from (206.193.250.146):
In Reply to: Weight of H farmall posted by Irv ( Ia) on February 07, 2012 at 15:25:08:
well, these are just estimates, but close enough. Belly pump =100lbs. Belt pully = 40 lbs. Swinging drawbar = 40 lbs. Fenders = 25 lbs each. So, not counting fuel, and hyd oil, etc, that is just 225lbs in accessories. Other things that can influence it are the type/size of tires, calcium in the rears, rim style.
so, if you went with $250 a ton for #1 scrap and approx 2 tons (4000 lbs), your offer would be $500. If the rear tires are truly 80%, they are almost worth the $500 alone. Scrap price can vary by location. Here it bounces between $250 and $300 per ton for #1
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
