Hi, dirt in the bottom of the fuel tank. You have to drain the tank on both sides and take the shut off fitting out of the bottom of the tank on both sides and clean the dirt out of them. Then remove fuel line at top of first filter and blow out with air. Also listen when you remove fuel tank filler cap that there is no vacuum, meaning the vent hole is plugged. My brothers 684 did the same thing and it was the remains of a ladybug in the bottom of the tank blocking the outlet.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
