Posted by Steve KS on February 20, 2012 at 16:47:32 from (50.93.238.11):
Just mounted a loader on my 1963 IH 706 and it's not working quite like I expected. First question, I'm using the side remotes on the shifter side then running hoses to the loader valve. Is only one of the outlets pressure? For some reason it only works w/ the tractor control lever pushed rearward. Shouldn't it work opposite just by swapping the hoses on the remotes?
Second question, there's a fairly loud squealing whenever the loader is working very hard and it doesn't seem to have enough power to lift up the front of the tractor. That's not normal is it? I know the rear remotes work well b/c the 3pt (aftermarket that plugs in the rear remotes) has enough power to pick up the rear of the tractor.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
