Posted by WD9ER on February 23, 2012 at 07:16:32 from (65.127.84.74):
I am attempting to remove the fuel injector pump to clean the crud out from behind the pump. I have removed the access on the front face of the engine block and am able to view the pump timing. What else do I need to remove to pull the injector pump? There is a nut in the dead center that I assume hold the shaft to the gear, but when I attempt to loosen it, the engine turns over. I could hold the engine with the engine crank, but I want to ensure that I am able to remove it and get the engine back to the correct timing. Is this easily accomplished or going to be a pain to get the timing set correctly? I am just removing it for cleaning purposes.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
