The pipe dope or teflon tape will fix the leak. Yes it is normal for the coolant to run out, the end of the capillary tube in stuck in engine coolant, that's how it measures the temperature. By any chance is the port in the block near the distributor? Did you get the distributor wet or when it gets warm is it spraying coolant into the distributor? Did you refill the antifreeze? When messing around with the gauge did you do some collateral damage to carb or ignition?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
