300U hyds loading tractor engine
Posted by Ricky on September 14, 2000 at 07:18:01 from (204.248.158.20):
When the valve is in the nuetral position the pump is loading the motor. When you engage the valve the lift will lift and the engine is not loaded. I took the check valve apart last nite and made sure all the valves were free and they are. Is the bypass valve in the control valve? Something is stuck somewhere and I don't know where to look. Let me know what you think.
Post A Followup
: Re: 300U hyds loading tractor engine
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
