Well, splitting the tractor seems like a bunch of work and probably a bit dangerous. I may just remove all the bearing caps to get a look at the crank journals, if they look good, I may just replace the sleeves, pistons and bearings and call it good. Is there a plasti-gage spec for the rod and main bearings on the 113 engine.
Also, can 3 1/8 inch bore sleeves be installed in this engine? seems to me I have ran across other posts on this site mentioning that. Being that the engine has a water pump, I should really use the 123 head gasket with the smaller coolant holes, correct?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
