Re: 140 Generator
Posted by John T on March 19, 2012 at 10:18:09 from (71.52.192.218):
In Reply to: 140 Generator posted by RTR on March 19, 2012 at 10:07:16:
I wouldnt call this foolproof and its far from perfect, but if you work through it, especially Para 5 where it shows how to full field the genny which by passes any Voltage Regulator or Cutout Relay problems, it ought to tell you if the genny is bad versus the VR etc. The Motor test also shows how to determine with a good probability whether the genny itself is good or not, as if it passes BOTH tests it will usualy charge.
As always, the Genny and the VR or Cutout Relay and the light switch (LHBD switches) allllllll require good grounds and its good to Polarize the genny if in doubt before start up if the system has been worked on.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=665110
John T
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
