Posted by Keven McNeice on March 23, 2012 at 07:44:06 from (216.26.194.212):
I got a new fan pulley and seal for my Farmall C. The original was unbelieveably hard to remove. By the time we heated it enough to pull off, there was steam (vapor) from the engine oil caps.
The manuals say that heating before installing is recommended, but the pulley has the seal surface area cast into it and contacts the seal. If its hot enough to go on, it would melt the seal.
We are considering dry-icing the end of the crank shaft, but that has me a bit concerned as well. I already busted the old pulley, not looking to break the crankshaft as well. Any thoughts?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
