I have in the past I have welded a bolt into the hole then let it cool and put a wrench on the bolt head and turnd them out. use the biggest bolt you can get into the stripped out square hole maybe even grind the threads off a little to be able to use a bigger bolt then weld around it the heat from welding also hepls to make break the plug loose or at least when it cools it shrinks a little making it come out.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
