Re: super c oil leak at brake pedal shaft
Posted by WellWorn on April 10, 2012 at 21:37:37 from (69.95.14.4):
In Reply to: super c oil leak at brake pedal shaft posted by old on April 10, 2012 at 17:44:57:
Quoting Removed, click Modern View to see Hi dandt,
It is an involved job. It may be just the seal, or the shaft itself may have a groove worn in it that a new seal won't fully cure. You won't know until you get it apart.
Are the tires loaded? You'll need to take the tire off that side and end up splitting the axle housing from the tranny. You will need a solid support for the tractor (secure blocking or preferably a quality jack stand), some means of handling up to 300# of tire, and a "cherry picker" for taking off and reinstalling the axle housing. A garage with a full coverage overhead crane and a caddy for tractor rears would be ideal.
Best bet is to get a service manual for the SC (available on ebay), look over the step by step procedure, and determine if you have the equipment to be safely up to the task before you start. I can't stress the safety aspect enough. Better to hire it out than risk damage to yourself (or your tractor).
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
