Posted by pete 23 on April 15, 2012 at 11:20:57 from (74.32.231.176):
In Reply to: IH 5488 shifting?'s posted by Dave from MN on April 15, 2012 at 07:21:10:
All gears are syncromesh except reverse and therefore should be very little grinding of any forward gear and you can shift them when moving. I would make sure the clutch pedal is properly adjusted and you have zero clutch pressure when fully depressed. Not unusual for a little difficulty shifting when cold due to drag of oil in main clutch. Later ones changed the lube to clutch valve for less lube flow on clutch making them better to shift when cold.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
