Posted by L.C. Gray on April 27, 2012 at 03:51:10 from (76.0.106.162):
In Reply to: Spark plug extensions? posted by Crazy Red Power in SE-WI on April 27, 2012 at 01:40:43:
Yep definitely a JC Whitney overhaul avoidance device
They basically raise the heat range of the plug by extending the effective distance to disipate the heat from the electrodes and insulator to the head to keep the plug extra hot and burned off clean enough to continue firing.
I doubt they did anything to avoid knocking... but then again you'd need compression for that and if you had compression you prolly wouldn't need the firing cups.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
