Re: stuck piston
Posted by toymaker 27 on April 27, 2012 at 07:47:01 from (216.232.230.13):
In Reply to: stuck piston posted by longear on April 27, 2012 at 05:53:51:
If you have pulled the crank off it should slide out the bottom, some time I have had to use a bigger hammer and a block of wood.
if removing out the top rust may be behind the rings preventing them from colapsing
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
