The information John T gave you is on the right track. However, some of the details (proper lag angle and how to set it) depend on what model magneto as well as the application. I don't believe you have mentioned a model id for the magneto. Most letter series IH tractors call for a 35 degree lag angle. If your timing gear marks are all in line, with the engine at TDC, the magneto drive lugs should be 35 degrees above horizontal oriented at 2 o'clock 8 o'clock. Lag angle setting in the magneto will have an effect on whether you can properly mount it.
This manual covers 3 Wico magnetos, each considerably different from the other. If yours is covered, good. Otherwise it may call for some more digging.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
