Posted by Scottydog on May 20, 2012 at 08:38:02 from (173.202.148.198):
I've got a good running (normally) 300 with some carb isssues right now. While plowing, the carb flooded on us and wouldn't start. We dropped the lower carb off to check it out and lost the needle. Picked up a new needle and gasket and reassembled. It ran perfectly for a couple hours without missing a beat and then stalled out. The carb was flooded again, but after removing the carb, inspecting and reassembling, we can't get it to fire. Anything I'm missing with the needle or float? (no leaks in the float). Fuel is flowing fine from the bowl to the carb. Float adjustment? Anything to look for with the needle? Thanks!!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
