Re: Another 756 leak
Posted by The tractor vet on May 21, 2012 at 07:06:02 from (75.19.119.253):
In Reply to: Re: Another 756 leak posted by flhr62 on May 21, 2012 at 02:53:45:
Drain the rear end , remove the three point arm and remove the two bolts and retainer and slide it apart replace the two O/rings look for a burrs and file them smooth polish with fine emery lube up and slide it back together . ONe before you start this remove the three point top link plate and look over to the right at the arm coming up from the bottom and see where it makes contact with the arm coming down from the top as the one from the top is on the back side of the one coming up from the bottom , if the one from the top slips off the one from the bottom your three point will go all the way up and not go down . This may happen when you start moving things . This little tid bit will keep you from coming back on want to know WHY MY THREE POINT WILL NOT GO DOWN.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
