Posted by kccoe on May 23, 2012 at 00:32:27 from (64.130.139.31):
I installed a ta eliminator kit on 1086 and the parts supplier failed to inform me or assume that I knew to replace the solid speed transmission main shaft with a hollow shaft with center drilled out or have the old shaft drill out .....I became aware that one should also replace the solid main speed transmission shaft with a hollow or drilled out shaft for lubrication after I purchased a ta eliminator kit for my other ih 1066 from a different parts house who inform me that I needed to. I hate to split the 1086 again and replace the shaft ... Any suggestions ?? Can I get by without replacing the shaft or risk some type of trans failure or bearing failure??
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
