Posted by TedinNE on May 28, 2012 at 06:35:32 from (74.85.105.220):
In Reply to: help 650 diesel posted by dAllen158/0 on May 27, 2012 at 18:48:42:
I don't know where you could find one. IH had a set up where you could hook it up between the injector line, was also the nozzle test kit. You could check the compression with it running on diesel. If you crank it over with the starter on diesel can you hear one cyl go over easier? Should be an obvious change with that bad of a miss. Sounds like you are low on compression on that cyl. They would have to be way off on the distributor valve shimming to make that bad of a problem.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
