More F-20 ? from a 17 yr. old
Posted by Adam on September 26, 2000 at 19:50:53 from (216.138.56.28):
here are some more questions about my F-20.
1. The head, after hot tanking shows cracks. One is from the spark plug hole out onto the compression dome and then stops. The other is on the top where the rocker arms mount. How should this be fixed because I would like to keep this tractor number matching for shows.
2. Does anyone know if NAPA or anyone else carries the timing cover gaskets? How about the gaskets that go between the parts of the manifold?
3. If you've got a good picture of a 39 farmall.... POST IT! I have decided to use this as the focal point of my lifes collection.
Thanks Guys
Post A Followup
: Re: More F-20 ? from a 17 yr. old
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
