Missing, if random, and less than 3 a minute is probably OK. If seeming to come from a single cylinder, and often, find the cylinder by removing and grounding one plug wire at a time till the missing (not the dead cylinder) stops. checking the distributor cam for sloppy bushing issues, No more than .001" play side to side, up and down.
check plug wire conductivity.
Check for vacuum leaks.
Check the valve adjustment
The governor linkage might be binding The throttle plate could also be binding (not centered when warmed up)
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
