Re: spark plug for 706 gas
Posted by Owen Aaland on June 08, 2012 at 14:18:53 from (216.47.35.61):
In Reply to: spark plug for 706 gas posted by Matt S Illinios on June 08, 2012 at 11:14:51:
Champion D18Y or another brand of comparable heat range.
For heavy use you can use D15Y or for light use you could use D21.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
