Posted by oldiron29 on June 09, 2012 at 03:41:28 from (74.88.11.200):
In Reply to: F14 fuel pump posted by pete_w on June 08, 2012 at 19:18:33:
Pete, Disconect the fuel line to the carb and crank. You should get a good blast of fuel shot 6-8" out of line. If not first remove and clean check valves in pump. Second still no better Check push rod for wear should be 7 1/16" long with good flat ends. Or complete rebuild kits are avable. oldiron29
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
